4WD drive light flashing?
  • Fyffe
12 years 11 months ago #92610 by Fyffe
4WD drive light flashing? was created by Fyffe
The jams been off the road for about 4 months now and when i took it out today the 4WD light was flashing, and i seem to remember the light being solid on last time?
Any ideas folks?
  • jonesyba420
12 years 11 months ago #92612 by jonesyba420
Replied by jonesyba420 on topic 4WD drive light flashing?
Leak in the vacumn hoses for the hubs is the usuall culprit.
  • deedar
12 years 11 months ago #92621 by deedar
Replied by deedar on topic 4WD drive light flashing?
Leak in vacum best thing is to get some manual locking hubs
  • rut
12 years 11 months ago - 12 years 11 months ago #92623 by rut
Replied by rut on topic 4WD drive light flashing?
pull rubber hoses of were they join on to the steel pipes that head down to the wheels, these are on the left side of engine just below bat. start car put in 4wd one pipe should have vac with finger on end of pipe, then put in 2wd other one should have vac.
if ok put pipes back on and remove wheel, pull pipes from were the steel pipes from above join rubber hoses to hub again start car and do same thing in 4wd and 2wd.
this will tell you were the leek is.
if you have vac there then its your hub seals.
remove 6 bolts from hub remove hub smear a bit grease around seal and replace.
did you get my PM by the way?
Last edit: 12 years 11 months ago by rut.
  • Fyffe
12 years 11 months ago #92633 by Fyffe
Replied by Fyffe on topic 4WD drive light flashing?
Thanks for the help lads, will take a look tomorrow.
  • Fyffe
12 years 11 months ago #95601 by Fyffe
Thanks for that bill much appreciated! I've replied to your personal mail now.
Thanks again.
Time to create page: 0.090 seconds
