Spring spacer size
  • Lecras
12 years 11 months ago #92389 by Lecras
Spring spacer size was created by Lecras
Hi,
Can anyone tell me the dimensions of a 2 in spring spacer inside diameter outside diameter etc
I have a friend with a new lathe and loads of ali cutoffs!
Thanks in advance
Will
  • whalleyrange234
12 years 11 months ago #93624 by whalleyrange234
Replied by whalleyrange234 on topic Spring spacer size
I'm working on making some spring spacers at the moment.
65mm internal daimeter with a 20mm wall thickness should do it, im using some 3" gas pipe with plate welded on the end and a 65mm hole in center.
Time to create page: 0.067 seconds
