Swapping door locks over, is it possible?
- Back in Black
12 years 11 months ago #92265
by Back in Black
Swapping door locks over, is it possible? was created by Back in Black
Unfortunately I appear to have so much sand/earth in the drivers door lock that it will no longer rotate / unlock with the key. Currently having to lean in through the passenger side to pop the locks! With the increase in height its quite a stretch and I keep getting covered in mud leaning on the passenger side sill reaching across
- and obviously there's no way I'm cleaning Jimny
I've been looking at adding a remote to the central locking (as seen on here), but in the meantime, is it possible to swap the barrels over from the passenger side or back door to the drivers door? Me and electrics are not the best of friends, so probably safer to swap the locks rather than ar5e the central locking up.
Any guidance gratefully received, please
12 years 11 months ago #92306
Replied by helijohn on topic Swapping door locks over, is it possible?
I couldn't get the actual barrels out of the locks as the end is reamed fitted or such like. I was wanting to repair the tumblers after chummy had marmalised them.. If it is clogged could you not somehow blast out the muck using some high pressure while the lock is off the car or sluice it out. I can't see why you couldn't swap the complete barrel assembly with levers over if it is necessary. I'm trying to recall if the lever was reversible. Thing to do is try.
Time to create page: 0.074 seconds
