Fitting spring spacers and extenders ?
  • piprice
12 years 11 months ago #91871 by piprice
Thanks to dunnin I received my coil spacers and shock extenders...
Question now is how can someone just explain how it works...
And what needs doing or modifying etc
Attached some photos...
There's prob guides with photos but I've had a quick look and haven't found a lot...
Is it a case of jack up, let wheels droop and take out the shock bolts and the spring comes out when the shock is removed....
Also any photos of how the front shock extender goes?
Dunnin kindly provided me with some box section!
Thanks
  • piprice
12 years 11 months ago #92002 by piprice
Replied by piprice on topic Fitting spring spacers and extenders ?
Looking at other shock extenders the ones I have are some what different?
Anyone clarify?
  • Dave cc
12 years 11 months ago #92005 by Dave cc
Replied by Dave cc on topic Fitting spring spacers and extenders ?
Search me pal looks like some sort of home made thing guess the brackets bolt onto the rear shocker lower bolts to lift the mounting position of the rear shock but cant see anything to extend the fronts and the spacers must sit on top of the springs what are the spacers made from look like nylon or somthing like that in the photo :unsure:
  • Wiltec17
12 years 11 months ago - 12 years 11 months ago #92006 by Wiltec17
Replied by Wiltec17 on topic Fitting spring spacers and extenders ?
My shock spacers have a nut welded on the inside of the box section so the shock thread passes through a hole in the bottom with a nut to secure it, then the original mount hole has a bolt through and into the welded nut, I believe idiotmobil made them himself so maybe able to shed some light.
The other type I have fitted to a jimny have a thread welded to the top of the box section with a hole at the bottom, same principle except the original hole had a nut screwed onto the thread instead of a bolt into the nut. :silly:
Last edit: 12 years 11 months ago by Wiltec17.
  • piprice
12 years 11 months ago #92024 by piprice
Just been out to check and they are correct the angle of the photo makes it look wrong!
Attached some new photos now!
  • piprice
12 years 11 months ago #92054 by piprice
Cheers rich!
I can make clamps out of thread bar and some angle iron and some nuts
Can I not carefully cut the blocks to allow the rear spring to sit?
Time to create page: 0.095 seconds
