Grinding Noise When Pulling Away From Stop.
- Jimnyash
17 Nov 2013 15:14 - 18 Nov 2013 06:19 #91567
by Jimnyash
Grinding Noise When Pulling Away From Stop. was created by Jimnyash
Hi,
A question for you guys:
Today when pulling away from a junction the front of the Jimny seemed to make a grinding noise. I could feel a judder from the front, but through it was simply from the front wheels slipping (tight left hand lock on wet roads).
I dismissed it.
But upon stopping and then having to pull away again, it does it. It sounds like a metallic grinding slipping kind of noise.
It comes from the front and happens in 2WD.
I've put the car into 4WD and can hear both hubs locking and unlocking as required.
Any thoughts on what it could be?
I'm on standard suspension with no mods apart from slightly bigger 215 tyres.
Thanks for any ideas.
I dismissed it.
Last edit: 18 Nov 2013 06:19 by Jimnyash.
- Jimnyash
18 Nov 2013 06:20 #91796
by Jimnyash
Replied by Jimnyash on topic Grinding Noise When Pulling Away From Stop.
Nobody?
Oh well, off to the garage today.
- craigy123
18 Nov 2013 09:40 #91821
by craigy123
Replied by craigy123 on topic Grinding Noise When Pulling Away From Stop.
Brakes? Worn pads, binding caliper?
- GuardianAngel
18 Nov 2013 10:04 #91825
by GuardianAngel
Replied by GuardianAngel on topic Re:Grinding Noise When Pulling Away From Stop.
Any oil in the diffs? Have they taken in water?
18 Nov 2013 10:22 #91831
Replied by mlines on topic Re:Grinding Noise When Pulling Away From Stop.
All the above, plus stone trapped behind the disc shield.
- Jimnyash
18 Nov 2013 11:21 #91839
by Jimnyash
Thanks for the ideas guys. They're all worth a look.
Seemed odd it would only do it pulling away and there was no other noise in any other gears or at any other speed.
Haven't done much deep water so would home it's not water in the diffs, the oils were only changed a few thousand miles back.
Will keep you informed.
