KING PIN BEARINGS
- jimothy
17 Nov 2013 14:32 #91560
by jimothy
KING PIN BEARINGS was created by jimothy
Hi I have attempted the King pins bearings today only to find a problem. How do I access the bolts to the hub with the ABS Ring in the way. the heads of the bolts look a bit iffy. I did manage to get one of the bolts loose with a spanner but access to the bolts is very tight. So I want good access with a socket if I can. The only way I see of doing this is to remove the wheel bearing. This means buying the right socket as I don't have one. Am I right as the How to do guild does not show a model with ABS.
- markyp2000
17 Nov 2013 16:03 #91571
by markyp2000
Replied by markyp2000 on topic KING PIN BEARINGS
You dont have to undo them bolts i never have
- jimothy
17 Nov 2013 16:18 #91578
by jimothy
Replied by jimothy on topic KING PIN BEARINGS
Do you just remove the circlip and top and bottom king pins and pull the whole thing off..
17 Nov 2013 17:33 #91601
by j999pre
Grey pick up Jimny
Replied by j999pre on topic KING PIN BEARINGS
Undo the king pin bolts 4 x 12mm top and bottom. Discount steering bar or bars depending which your doing. Take off the caslipet. Undo the 8 x 10mm bolts holding the spherical seal on and pull the whole lot off. You can leave the VAC hub and shaft on.
Grey pick up Jimny
17 Nov 2013 19:19 #91635
Replied by helijohn on topic KING PIN BEARINGS
And I find that a low profile ring spanner preferable with only six faces is the best way to deal with iffy bolts in the first instance.
Time to create page: 0.094 seconds
