need help for half shafts + cv
17 Nov 2013 11:05 - 17 Nov 2013 11:06 #91541
by safari
if u worry u die if u dont worry u still die so why worry
need help for half shafts + cv was created by safari
i am after a pair of second hand cv with half shafts ,i have a 1998 from japan with abs .i need to know how to recognise the difference between mine and others axles to fit mine so i can buy from this forum ,in malta i ran out of cv and new r too expensive pls help
Last edit: 17 Nov 2013 11:06 by safari.
20 Nov 2013 07:21 #92238
by safari
Replied by safari on topic need help for half shafts + cv
no one knows how to check for a half shaft with cv if its fits or not ?
mine is jimny wide with abs 1998
20 Nov 2013 07:46 #92245
by j999pre
Grey pick up Jimny
Replied by j999pre on topic need help for half shafts + cv
If the drawing you posted is what you need then I will check mine for you.
Grey pick up Jimny
20 Nov 2013 07:55 #92246
by safari
ok tks
20 Nov 2013 21:33 #92396
by kirkynut
Replied by kirkynut on topic need help for half shafts + cv
I've only just seen this and it's a bit cold / late for me to go back out now - I've been up since 05:00!
I can look at my spare shafts another day if you can wait and no-one has beat me to it - mines a 2000 model with no ABS.
22 Nov 2013 10:15 #92591
by safari
tks need to know what can fit mine so i can buy from here mine is with abs tks again for the help really need itkirkynut wrote: I've only just seen this and it's a bit cold / late for me to go back out now - I've been up since 05:00!
Time to create page: 0.109 seconds
