Front diff fitting help.
  • Dave91
15 Nov 2013 10:54 #91258 by Dave91
Front diff fitting help. was created by Dave91
Hi everyone! I'm going to try and replace my front diff tomorrow and I thought I'd ask on here first if there's anything I should watch out for? I've taken the shafts out before without a problem am I right to assume its a pretty simple job after that? Any advice or tips would be helpful :)
  • whittleos
15 Nov 2013 11:01 #91259 by whittleos
Replied by whittleos on topic Front diff fitting help.
drail oil then jack up put on axle stands take half shafts out then your diff will pritty much fall out make sure when you fit new one you clean all around where it seals .
  • Dave91
15 Nov 2013 11:23 #91262 by Dave91
Replied by Dave91 on topic Front diff fitting help.
Cheers mate! That doesn't sound too difficult.
  • adamjimny
15 Nov 2013 11:50 #91268 by adamjimny
Replied by adamjimny on topic Front diff fitting help.
it'll take all day so don't rush as both front hubs to come off etc to get shafts out then diff will come out......done 4 myself on mine
  • whittleos
15 Nov 2013 11:54 #91269 by whittleos
if you got the correct tools such as a 8 mm for hubs and then sir clip pliers and 12 mm for your kin pins etc it would take max of two hours . its a easy job just make sure you drain oil and you have on axle stands better to have them then it drop on you :) . also the diff is not to light so be careful your head is not under it may hurt a bit ha . and use a tub for your buts and bolts and clips don't want grit in them . id clean around your hub seals etc wile i was there to take 10 min a side easy done :)
  • whittleos
20 Nov 2013 18:59 #92353 by whittleos
did you manage to get it swapped over ?
Time to create page: 0.382 seconds
