Rear shock bolts
  • Tommo
13 Nov 2013 16:02 #90889 by Tommo
Rear shock bolts was created by Tommo
What have people done to stop them coming
Loose,
I have the shock relocator brackets
Should I now use extended bolts?
But the standard ones keep coming loose?
13 Nov 2013 17:18 #90907 by kirkynut
Replied by kirkynut on topic Rear shock bolts
You could drill the mounting as many people do - I am yet to do it but think I shall do so. Then use a longer bolt and a nyloc nut or two nyloc nuts so they lock each other, or get some studding and do the same - or just do the standard bolts up tighter with some thread lock!
  • Goat
13 Nov 2013 18:09 #90923 by Goat
Replied by Goat on topic Rear shock bolts
I carried spare bolts and tighten it up every couple of hours. Thinking of drilling mine as its a pain having it come loose all the time.
  • Tommo
13 Nov 2013 19:33 #90954 by Tommo
Replied by Tommo on topic Rear shock bolts
with the shock brackets
on jimnybits they give you an option to have longer bolts
but the thread is too big, and the bolt is too long
I managed to find 1 bolt I had that fits pretty good, but I had to cut it down abit
and pack the rest out with washers and it seems s tight fit, hopefully it wont come loose
but on the left side it still has the original bolt, but that only grips by about 3 or 4 threads, so its only just in there
  • Dunnin21
13 Nov 2013 20:28 #90974 by Dunnin21
Replied by Dunnin21 on topic Rear shock bolts
I drilled mine last night took me 30mins to do both. Used m12x 160mm bolts could have got away with 150mm now carry a spare set of nuts and bolts in car if it snaps while I'm iff roading its a easy 2min job. Would reckomend it anyone.
  • Tommo
13 Nov 2013 20:52 #90983 by Tommo
yeah I think i'll do mine, what did you use, a 12mm drill bit?
Time to create page: 0.119 seconds
