Technical - ish winch question
  • jimnydms
12 Nov 2013 19:45 #90652 by jimnydms
Technical - ish winch question was created by jimnydms
On my quest to buy a winch at the moment I am seeing such things as "minimum 650 CCA requirement for winching" I understand that is related to the battery but are they basing that on the user using the winch with the engine off and running on battery alone or having the engine on will still mean you need a certain CCA battery requirement ? If anyone could alloborate would be more than grateful !
  • TomDK
12 Nov 2013 21:35 #90680 by TomDK
Replied by TomDK on topic Technical - ish winch question
The CCA is cold cranking amps. Meaning how many amps the battery can throw at the winch, starter motor or whatever. The higher the CCA the better. If the CCA isn't high enough, then your winch will not get the amps it needs to perform as it should.
But the battery is only part of it.
Always remember to use good cables and a good solenoid (Albright). I never use anything less than 50 mm2 cable, preferably 60 mm2.
  • jimnydms
12 Nov 2013 21:52 #90698 by jimnydms
Replied by jimnydms on topic Re:Technical - ish winch question
Ok perfect I ll bare that in mind when I'm ordering my bits as I need to re locate the electrics that come with the warrior winch under the bonnet with the design of the o.r.a bumper
Cheers
  • TomDK
12 Nov 2013 21:57 #90704 by TomDK
Replied by TomDK on topic Re:Technical - ish winch question
What Warrior winch have you got?
  • jimnydms
13 Nov 2013 09:21 #90818 by jimnydms
from my other post, I havnt got any yet just making sure im prepared and have the right info before making the correct choice and having to buy everything once not twice because of lack of knowledge lol
Time to create page: 0.209 seconds
