Rear axle
- DonegalGuy
13 years 1 week ago #90404
by DonegalGuy
Rear axle was created by DonegalGuy
Ok I'm really confused as to the reasons behind my rear axle measurements??? :S
Taken some measurements from the chasis out to the outer edge of the wheel on both sides of the jeep.
The drivers side measures 12 1/4" at the front of the wheel and 12 1/4" at the back of the wheel.
The passenger side measures 13 1/8" at the front and 12 7/8" at the rear giving me 1/4" of toe out on the passenger rear wheel as well as seeming to have an axle off centre?
Dont think it has been lifted but upon taking measurements from ground to underside of wheel arch i'm getting 29" at the front on both sides, 28 1/4" at the rear drivers side and 29 3/4" on the passenger side?
If my axle is off centre maybe the wrong panhard rod has been fitted? It measures 36 1/2" hole centre to hole centre.
I'm wondering if I have bushes in a bad state in the radius arms, or if they have moved or are badly fitted?
- vitara_mad
13 years 1 week ago #90491
by vitara_mad
Replied by vitara_mad on topic Rear axle
first thing I would check is bushes in the rear arms
- zuki andy
13 years 6 days ago - 13 years 6 days ago #90504
by zuki andy
Replied by zuki andy on topic Rear axle
In theory a rear axle should be straight, so if one side was toe out the opposite should be toe in. have you tried measuring the wheel base, see if that varies from side to side? also put the front wheels dead straight ahead, and then use a straight edge or string across the front & back wheels to see if this shows the same results your getting from measuring from the chassis. your panhard rod is the correct standard length.
Last edit: 13 years 6 days ago by zuki andy.
- markyp2000
13 years 6 days ago #90506
by markyp2000
Replied by markyp2000 on topic Rear axle
Body hight should be messured from the center of tye hub to the under side of the wheel arch cos if your ture pressures are not set the same or the tread depth is different of on uneven ground there is only one messurment you need todo on the rear messure from the top center of the wheel on the inner edge to the chassis
Dont worry about the differents between the front and rear of the wheel
Time to create page: 0.082 seconds
