Handbrake light stays on.
23 Sep 2015 15:24 #152426 by j999pre
Replied by j999pre on topic Handbrake light stays on.
It's your ignition switch that it's a bit worn.
Grey pick up Jimny
02 Oct 2017 20:30 #184760 by yakuza
Yellostreak wrote: the brake warning light serves both the handbrake and also the fluid level..
If its still not working then its either the ignition switch or ABS if you have it fitted.
from the manual
So i had my ignition switch out today cause I have the same problem with the light that stays on. Tried unhooking both handbrake and fluid level switch, and light still on, so thought it would be the switch. It was actually serviceable so had it open and it looked very nice inside, no wear or anything broken. If you ever open yours, keep the white part down or springs will fall on your messy floor and you will search for it for a long time unless you are very lucky like me and find it right away...
Anyways I have only the ABS to check now. Does anyone know how to?
Sent fra min E5823 via Tapatalk
02 Oct 2017 21:27 #184762 by yakuza
Replied by yakuza on topic Re:Handbrake light stays on.
Picture shows the switch on the steering column opposite the lock, and the switch dismantled. Six small springs, two shiny discs. Contact points on the black piece.
03 Oct 2017 17:22 - 03 Oct 2017 17:23 #184801 by yakuza
Does anyone know where to find the diode in the line from the handbrake light to the ABS shown in the scheme/page from the manual above?
Last edit: 03 Oct 2017 17:23 by yakuza.
05 Oct 2017 06:09 #184858 by yakuza
yakuza wrote: Does anyone know where to find the diode in the line from the handbrake light to the ABS shown in the scheme/page from the manual above?
Found DIODE #1 in the manual, supposed to be behind the stereo. will look at it later..
15 May 2018 10:30 #192707 by yakuza
My brake light still shines.. all the time.
I will adress the problem again some time soon and was wondering if aynone has had any more updates or experiences on this lately?
to recap:
unhooking switches on brake fluid reservoir and hand brake switch does not make the light go off.
Ignition switch does look great and no has no play for wiggling it.
Unhooking ABS fuses and/or abs central unit only made the ABS light come on, brake warning still shines.
Never found the diode in the dash as noted in the diagram from the manual.
Diode still looks like it only stops signals from reservoir to return to ABS unit.
I will try to follow the wires from the bulb in the dashboard cluster and measure where the signal comes from if possible.
Time to create page: 0.720 seconds
