Alternator belt
- rexthecat
13 years 1 week ago #90304
by rexthecat
Alternator belt was created by rexthecat
Belt was squeeking away this eve, I did get it tightened the other day but maybe not enough? To tighten there's a tensioning bolt right but do I need to loosen something first?
Cheers
Cheers
13 years 1 week ago #90325
by facade
Replied by facade on topic Alternator belt
There is a lower pivot bolt on the alternator, you can feel it if you get your hand under the alternator pulley through the fan belt. It has an allen key head.
It won't come undone
Don't bother trying to undo from the back, above the axle, as that end is a welded on nut.
I had to dismantle virtually the entire car and remove the alternator on the bracket to get mine undone. :ohmy:
You sure it isn't the power steering? That adjusts by rotating the tensioner and is dead easy.
(You can always squirt a bit of pledge on the ribbed side to quieten it down for a couple of weeks
- rexthecat
13 years 1 week ago #90334
by rexthecat
Replied by rexthecat on topic Alternator belt
Ha as in pledge window cleaner? Id heard you could use soap, I think it may be the other belt, the guy at the garage did it with a spanner and socket in 2 min, I'll have a look.
Cheers
Cheers
13 years 1 week ago #90337
by kirkynut
Replied by kirkynut on topic Alternator belt
The Allen key will come undone with perseverance, a good fitting Allen key and maybe a bit if tube over the end of it to add some leverage. As long as I didn't do it up that is, but I've not been on a spree of Jimny bolt tightening in the UK yet!
- rexthecat
13 years 1 week ago #90348
by rexthecat
it was the power steering belt, so in theory easy....in practice the bolt was stuck and now i've rounded it a bit......bluddy ell! I used a metric spanner....I guess its imperial nut? Anyhow so now the question is any ideas how to get it out and replace, just the locknut on the tensioner.........file it square again and maybe a bit of heat to loosen?
It's a learning curve innit but takes me 3 times as long to fix owt due to buggering it up in the first place then learning how to put it right, I put a snorkel on in the constant rain on Sat, was quite nice morning when I started but theres nothing to slow you down like pouring rain and a template that dont fit! got there in the end.....quite happy with it though, does seem to let the engin rev a bit more freely, its an auto box and did seem happier on the long slow hills.
Cheers
Cheers
13 years 1 week ago #90462
by facade
Pledge furniture polish, it's only 99p a can
proper belt lube is about £7 and there won't be a can under the sink already. :lol:
Anything will do as a bodge, no substitute for a new belt/correct tension though
rexthecat wrote: Ha as in pledge window cleaner? Id heard you could use soap,
Time to create page: 0.089 seconds
