Caliper carrier bolts
  • Dougall
08 Nov 2013 19:48 #89985 by Dougall
Caliper carrier bolts was created by Dougall
I was changing my discs and pads this evening (well, trying) when I discovered one of the 17mm bolts on the caliper carrier was completely rounded. Does anyone know where I can get these bolts, and also a good method of getting the old one off?!
  • gilburton
08 Nov 2013 19:52 #89986 by gilburton
Replied by gilburton on topic Caliper carrier bolts
Apart from heat/brute force or a grinder try these
www.ebay.co.uk/itm/Irwin-Bolt-Grip-Remov...&hash=item2330d8d722
  • Dougall
08 Nov 2013 19:57 #89988 by Dougall
Replied by Dougall on topic Caliper carrier bolts
I've seen recommendations for them from a few places - the only thing that worries me is the maximum size is 16mm and the bolt head is (was, before being rounded) 17mm.
Think I may have to speak to Suzuki and order some new bolts.
  • markyp2000
08 Nov 2013 20:48 #90000 by markyp2000
Replied by markyp2000 on topic Caliper carrier bolts
Are you using a 6 sided or 12 sided socket/spanner try hitting a 16mm 6 sides half inch scocket on it
  • Dougall
08 Nov 2013 21:51 #90025 by Dougall
I was using a 6 sided 3/8" socket. Was tempted to try hammering a 16mm onto it but I'd rather have a new bolt in my hand first before destroying the old one - at least it's still driveable for now as the old bolt hasn't moved a bit. It's soaking in plusgas tonight so I'll try a 16mm socket when I've got the new bolts or even file two flat edges onto the bolt to get a flat spanner onto it.
Any suggestions other than suzuki for the bolts? The workshop manual doesn't give much indication to their pitch/strength.
08 Nov 2013 22:35 #90043 by kirkynut
Replied by kirkynut on topic Caliper carrier bolts
Why on earth were you using an imperial socket on a metric bolt? No wonder it's rounded!
Try as Mark says in hammering on the 16mm and it might just work but don't put an open spanner on it or it will be buggered.
Time to create page: 0.094 seconds
