SJ Tran Box Noise...
- nzJim
04 Nov 2013 09:58 #89302
by nzJim
SJ Tran Box Noise... was created by nzJim
So I took the Jimny for a spin today to test my rebuilt SJ transfer box with 4.16 gears. Driving in 2H there is a pretty noisy whirring sound coming from the box.
Back at home I took off the rear shaft and ran it again in the garage in gear and the noise was there.
So I've eliminated the shafts themselves (the front is fine).
There are new gears through out and new bearings where required (not all). I don't have any experience with the SJ transfer case but I would be surprised if they're this loud! Does anyone know if it's the new gears bedding in, or something wrong - or is this normal?
Thanks in advance
Thanks in advance
- ne-crock
04 Nov 2013 10:49 #89305
by ne-crock
Replied by ne-crock on topic SJ Tran Box Noise...
tends to be that sj boxes are louder than a jimmy transfer box due to the meshing gears rathen than being chain driven,
i'd be lead to belive that due to the new gears and bearings this noise is heightened but is normal,
i know when i upgraded to redcution gears in my sj box i noticed the noise increase, but it was minimal over the exhaust,
i'm sure someone will be along to correct me if i'm wrong, but without being able to hear it, the noise you've described is normal
04 Nov 2013 17:41 #89341
by kirkynut
Replied by kirkynut on topic SJ Tran Box Noise...
It is par for the course I'm afraid as you have new gears meshing with old gears and they have different wear patterns so whine.
This is also not helped by the type of mounts we have to use as a bolt goes through the box mount and the chassis mount effectively transmitting the noise. The original mounts have rubber with studs bonded to each side which have the rubber between them to dampen the noise and stop it being transmitted.
You just have to live with it I'm afraid!
- idiotmobil
04 Nov 2013 18:00 #89346
by idiotmobil
Replied by idiotmobil on topic SJ Tran Box Noise...
yep all sounds normal, i asked the same qestion when i put mine in quitened down abit after 50 miles ish but its still loud you just need to learn to live with it im afraid
- steffan
04 Nov 2013 18:15 #89351
by steffan
Replied by steffan on topic SJ Tran Box Noise...
I have a funny little device on my dash that stops me hearing any noises it's called a radio turn the big knob clockwise a little bit more and you will soon have rid of any unwanted noises lol
- supergaz
04 Nov 2013 20:00 #89397
by supergaz
Replied by supergaz on topic SJ Tran Box Noise...
My Rockwatt Rocklobster is as quiet as a mouse even at 75mph.
Time to create page: 0.123 seconds
