hydraulics
03 Nov 2013 21:27 #89244
Hydraulic clutch actuation was "the" method back in the days of Ford Anglias and such and I absolutely hated it. When cable operation became commonplace I thanked the stars. Can you not rig up a cable system!
Replied by helijohn on topic hydraulics
Dave cc wrote: why would you want to do that ?
03 Nov 2013 21:57 #89248
by jimkyx
Replied by jimkyx on topic hydraulics
Try this website and type in "pedal box" it will give you all the options you need.
www.cbsonline.co.uk/
Not a lot of room in a Jimny to fit the master cylinder etc. Also topping up may be a problem.
You could try a remote master operated by the existing cable pedal but it all starts to get a bit messy as the cable is a pull and the master cylinder is a push. Another thing you might consider is that the operating mechanics between cable and hydraulic clutches are slightly different, so you may have to stick with the hydraulics to keep it driveable.
Time to create page: 0.087 seconds
