Tow-bar elec socket wiring
31 Oct 2013 16:27 #88747 by Halford
started wiring up my tow-bar socket today but got stuck and downed tools until I can get good advice as I don't know what I'm doing :blush:
got the first bit OK
function socketCar harness
Left indicatoryellowGreen/Red stripe
Right indicatorgreenGreen/Yellow stripe
Brake lightsredGreen / White stripe + dots
but here's where I stumbled, the socket has seperate wires brown (right light) and black (left light) and I'm guessing that both these socket wires connect to the single car harness wire as below:
Side lights
Right LightbrownRed / Yellow stripe
Left LightblackRed / Yellow stripe
and I also assume the earth connects as below:
earthwhiteblack
if someone can double check and confirm the above is OK (or wrong) I'd be very grateful
thanks
Halford
  • gilburton
31 Oct 2013 17:05 #88752 by gilburton
Replied by gilburton on topic Tow-bar elec socket wiring
if there is only one red/yellow wire feeding both rear lights then yes connect them together but if there are 2 find out which one goes where and connect them to the brown or black as appropriate.
The Earth is correct Black to white socket.
The idea of separate wires is you will still have one working tail light if one blows.
31 Oct 2013 17:13 #88753 by Halford
Replied by Halford on topic Tow-bar elec socket wiring
many thanks Gilbert ;)
will take it all to bits again tomorrow :S
  • gilburton
31 Oct 2013 17:32 - 31 Oct 2013 17:37 #88755 by gilburton
You don't have to use the car earth wire(black)
You can take the white wire from the socket and earth it anywhere on the car using an existing bolt or hole.
Just make sure you get a good earth and use a star washer to bite through the paint. :)
If you have reassembled it all and put the seats etc. back you could cheat and run a couple of wires from the rear light units and splice in to the tow bar wires at a suitable point?
I did something similar on my first Jimny.
Last edit: 31 Oct 2013 17:37 by gilburton.
31 Oct 2013 18:46 #88772 by Busta
Replied by Busta on topic Tow-bar elec socket wiring
When I wired mine up using the guide from this site, I found a couple of the wires were wrong/different. I didn't write down which though :unsure:
Anyway, you may find you have to play around a bit to get the right ones.
  • helijohn
31 Oct 2013 18:52 #88775 by helijohn
Replied by helijohn on topic Tow-bar elec socket wiring
Where physically are you tapping into the car wiring to do this please?
Time to create page: 0.182 seconds
