Missing at idle, only when hot.
  • Reckerr
13 years 2 weeks ago #88739 by Reckerr
Missing at idle, only when hot. was created by Reckerr
So my jimny just got a head swap and now everything is great except for a misfire at idle after driving for about 20mins - half hour. after it's well heated up. Any ideas. I cant remember if it was like this before th eengin work.
It's perfect after even a bit of rpms. at 1500. The miss is gone. Just at idle. And I can hear it sputtering from the exhause at lights and the rpm gauge shuffling up and done.
  • Dave cc
13 years 2 weeks ago #88749 by Dave cc
Replied by Dave cc on topic Missing at idle, only when hot.
Have you checked valve clearnce could be a tight tappet :silly:
Vacum hose off sucking in air maybe
Did you have the head apart before fitting to check valves are ok ? could have a burnt out valve that doesnt show up when the mixture is richer on start up but does as the mixture leans off again woulD show at idle but not at higher RPM if it was me would check the obvious then do a compression test
  • Reckerr
12 years 11 months ago #95294 by Reckerr
Replied by Reckerr on topic Missing at idle, only when hot.
Finally replying. A mech friend of mine looking at it and did some adjusting...No idea what he did. But Is it possible to set tappets by hand.
He just tightened them he said. Turned them a bit. Adjusted another set(tighter) but it's still running rough.
It's not really an rpm rough(as in gauge jumping, its pretty stable). But just engine rough(as in I can feel it). And a lack of power sometimes.
  • markyp2000
12 years 11 months ago #95319 by markyp2000
Replied by markyp2000 on topic Missing at idle, only when hot.
Tightening them up wont work as things get hot thay exspand so if you have a tight tappet it will hold the valve open take it some where and get the job done right first time then if its still the same look at some thing else
  • greenjimny
12 years 11 months ago #95333 by greenjimny
Replied by greenjimny on topic Missing at idle, only when hot.
try a coil pack swap common for them to break down when hot /under load
Time to create page: 0.108 seconds
