Why fit diff breathers?
- Leathery1
30 Oct 2013 19:18 #88642
by Leathery1
Why fit diff breathers? was created by Leathery1
Sorry if this is a bit of a numpty question, but what are the consequences of wading without diff breathers?
Does it do serious damage quickly or is just that you need to keep changing the diff oils as it emulsifies with any water which gets in there?
Went a bit deeper than I intended to at the week end!
- idiotmobil
30 Oct 2013 19:20 #88643
by idiotmobil
Replied by idiotmobil on topic Why fit diff breathers?
dont forget you have transferbox and gear box breathers so change the oil in them to
- Leathery1
30 Oct 2013 19:23 #88644
by Leathery1
Replied by Leathery1 on topic Why fit diff breathers?
Not deep enough to get to the gearbox and tbox - only up to the sills on a 3" lift.
Do i need to change the oil straight away? Only had it done last week!
- supergaz
30 Oct 2013 19:36 #88646
by supergaz
Replied by supergaz on topic Why fit diff breathers?
Drain it into a clean container and tip it back in if not contaminated.
- Leathery1
30 Oct 2013 19:40 #88651
by Leathery1
Good idea supergaz - guess I should fit them anyway cos I have a funny feeling I will be getting in deeper than I meant to on regular basis!supergaz wrote: Drain it into a clean container and tip it back in if not contaminated.
- jonesyba420
30 Oct 2013 19:47 #88652
by jonesyba420
Replied by jonesyba420 on topic Why fit diff breathers?
The ford in your other picture gets very deep,last time I was there I abandoned that one was way to deep!!i inadvertently had mine upto the bottom of the headlights with no snorkle
the gearbox breather is pretty high compared to the rest, diffs and t box probably the most important specially if your regulaly wading.
Time to create page: 0.182 seconds
