rev pick up
  • chris2010
28 Oct 2013 23:09 #88412 by chris2010
rev pick up was created by chris2010
Where does my single cam jimny pick up it's rev counter signal ?
  • Dave cc
29 Oct 2013 00:08 #88418 by Dave cc
Replied by Dave cc on topic rev pick up
Cam sensor i would suspect but chaces the actual signal will come via the ECU Rhinoman would answer this in a moment :unsure:
  • chris2010
29 Oct 2013 10:33 #88445 by chris2010
Replied by chris2010 on topic rev pick up
I'm just trying to work out how I will keep my rev counter working after a diesel is put in
My engine has got a crankshaft position sensor , I wonder weather this signal would be enough to get it working
Isuzus use the alternator , perhaps this is a possibility
  • gus2000
29 Oct 2013 11:49 #88451 by gus2000
Replied by gus2000 on topic rev pick up
The tachometer is connected to the ECM
ECM receives the pulses of camshaft sensor, processes it and sends the electrical signal to the tachometer
  • chris2010
29 Oct 2013 22:57 #88568 by chris2010
so does it have 3 wires going to it... 12v ign, earth and a signal wire back to the ecm ?
if so which colour wire is the signal wire to the ecm?
  • Dave cc
29 Oct 2013 23:23 #88570 by Dave cc
Im thinking trigger wheel on cam shaft pulley and point the cam sensor at it
could easily heath robinson a trigger wheel up and then stick it in a battery drill spinning in front of the cam sensor to test if it works
Time to create page: 0.150 seconds
