4WD not engaging
  • rut
13 years 2 weeks ago #88371 by rut
4WD not engaging was created by rut
Hi all
My 4WD is not engaging so went through the fault finding on here and after checking everything i have vacuum at pipes leading to hubs,
after removing the hub i found the large seal in the hub that can be seen when you remove the hub with out taking it apart has a bit missing about 10mm x 3mm on the edge i stuck some tiger seal on it as a temp fix to test it and it worked for a wile,
now my question is what is this seal called and are they renewable and if so were can i get one, and how hard is it to replace.
cheers rut
13 years 2 weeks ago #88391 by j999pre
Replied by j999pre on topic 4WD not engaging
You get them in the wheel bearing kit, post a picture to make sure we are talking about the same bit.
Grey pick up Jimny
  • rut
13 years 2 weeks ago #88401 by rut
Replied by rut on topic 4WD not engaging
can you buy them on there own?
13 years 2 weeks ago #88404 by kirkynut
Replied by kirkynut on topic 4WD not engaging
Yes, from a dealer.
If I'm honest, you may aswell just get fixed hubs off an old SJ / Vitara or get some freewheeling hubs and adaptor rings.
The vacuum hubs are just more trouble than they are worth in my humble opinion.
Time to create page: 0.075 seconds
