HELP! 06 Jimny sound system!
- OzJim
13 years 3 weeks ago - 13 years 3 weeks ago #88025
by OzJim
No eBay APP ID and/or Cert ID defined in Kunena configurationHELP! 06 Jimny sound system! was created by OzJim
No eBay APP ID and/or Cert ID defined in Kunena configurationHi guys... I am sorry, i know this has been covered before but I am still very confused. :S
I'm looking at a pretty cheap / mediocre sound system for my 06 Jimny. Nothing to fancy. I need some clarification on buying the right gear as it's the first audio mods i have done to a car... Can you guys advice on whether this stuff is compatible with the 06 Jimny? (the sites are for Aus but you should still be able to view them)
4x 4" speakers: www.jbhifi.com.au/car-sound-gps-navigati...-speakers-sku-91044/ (will these fit the two front side stock speaker slots as well as the two rear slots)
I have also found this, I don't know how to explain it other then will this work instead of paying hundreds for a new fascia: www.aliexpress.com/item/11-357-Car-Radio...scia/1324493949.html
IF that works can I then fit this Double din head unit: www.sonicelectronix.com/item_45806_JVC-KW-R500.html
And finally I would be looking at buying this under seat 10" sub + amp:
Thanks very much! Jack.
Last edit: 13 years 3 weeks ago by OzJim.
13 years 3 weeks ago #88030
by Halford
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by Halford on topic HELP! 06 Jimny sounds system!
4x 4" speakers OK for front, but for rear go bigger -
see here
that Car Radio Fascia should work fine with the JVC double DIN head unit - see here
guide to removing rear panels
but first you need to
remove the rear seats
and
centre panel dash removal
and
The following user(s) said Thank You: OzJim
13 years 3 weeks ago #88058
Great link,
wish I'd read something like this but for an earlier motor before I had to rip out my dash cos the radio wouldn't come out.
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by helijohn on topic HELP! 06 Jimny sounds system!
Halford wrote:
and
Great link,
- Stori
13 years 3 weeks ago #88126
by Stori
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by Stori on topic HELP! 06 Jimny sounds system!
I upgraded the sound system in my 04 jimny yesterday. There are a few areas to watch out for but nothing major. Depending on if you want to start cutting panels make sure the speaker profile will fit within the depth allowed. Youll notice when disconnecting the front speakers there is a distinct lack of + / - labeling. you can find out Which is which by googling but in short the connect closest to an arrow shaped clip is the +.
However.. to be aware (I am trying to fix today) the panel that goes back over the top is not a snug fit and if anything slightly off centre. This has meant there is a rather noticeable distortion of sound. They will either be off or I may try some felt backing.
13 years 3 weeks ago #88131
Is that the panel in the footwell. Mine have been on and off so often they are more or less flapping about. :laugh: I am tempted to leave them off but it looks a bit too utility like that.
Nice info about the leads +ve and -ve; it all helps.
Stori wrote: the panel that goes back over the top is not a snug fit
- jonathan
13 years 3 weeks ago #88137
by jonathan
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by jonathan on topic HELP! 06 Jimny sounds system!
www.aliexpress.com/item/2006-2012-Suzuki...Audio/530543949.html
here is the link to the one i got for mine and it is great and looks the part in the dash
Time to create page: 0.105 seconds
