Kinda knocking noise
  • parriehunter
25 Oct 2013 02:24 #87842 by parriehunter
Kinda knocking noise was created by parriehunter
Hi Guys and Girls,
I have 99 with a G13BB, I had the timing belt changed and since then there is a kind of knocking noise present. It does not sound like a Big End to me, not as extreme as I have heard other engines.
It goes not make the noise when cold and does get louder when at operating temp. The peak noise is at 1000-2500rpm and at idle you cannnot hear. I have spent a bit of time with my head in the engine bay trying to hear where the source is but cannot hear nearly as clearly as when in the cab.
It is constant with revs, the more revs the faster the sound. Doesn't mater if i am in gear or not in gear, moving or stationary.
No noticable oil use, I also did have an oil change done at the same time. Before i go back to the garage that did the work i am just getting an idea of what it could be.
  • 1sparky
25 Oct 2013 07:07 #87850 by 1sparky
Replied by 1sparky on topic Kinda knocking noise
Hi m8 have u got long screw driver ? If so use it as a stefascope and put it on parts off the engine when it's running and listen then u sound hear where it's coming from.
Iv put a post on here about both my g13bb engine as both of them have piston slap :-( sound a bit silly but one of the engines only start slapping after I changed the oil.
  • Zetec
28 Oct 2013 05:13 #88282 by Zetec
Replied by Zetec on topic Re:Kinda knocking noise
Hi
Did the garage do an engine flush before the oil change.
28 Oct 2013 07:12 #88294 by kirkynut
Replied by kirkynut on topic Re:Kinda knocking noise
It's not something silly like the cambelt cover catching on the pulley is it? Have you removed the cover & run it up to see if you can see what the problem is?
  • parriehunter
28 Oct 2013 22:17 #88398 by parriehunter
Replied by parriehunter on topic Kinda knocking noise
Thanks for the replies. Was at a mates palce who is very mechcainically minded and he has said it is a strage noise. Using a screw drivier we were unable to find the source.
I am unsure if an engine flush was done. They did not charge me for one so i guess that they didn't.
I haven't taken the cover off yet but i guess that i need to take the fan belts off first and then the cover, or can just the cover come off? That is a very good thing to look at.
It is definitely the warmer the engine the louder the noise.
  • parriehunter
06 Nov 2013 22:09 #89716 by parriehunter
Ok, have had a look at the cam belt, nothing obverious catching there.
Have done a lot more testing etc and a noise is coming from under the rocker cover. My thinking is that the garage adjusted the timing a little bit and maybe I have one or more bad tappet that has come out of adjustment?
For the single cam g13BB what is involved in adjuating the tappets? I have adjusted tappets before on an old bettle (very easy to work on).
I have found the pages in the service manual and it says it needs special tool, has anyone done this before?
Time to create page: 0.172 seconds
