Rocklobster
- RichiesJimny
13 years 3 weeks ago #87788
by RichiesJimny
Rocklobster was created by RichiesJimny
My rocklobster goes into 4wd with no problems but is really difficult to get back into 2wd the lever just won't budge the levers not catching on the body or the transfer box but it just won't go into 2wd without a fight. Any ideas ?
- steffan
13 years 3 weeks ago #87791
by steffan
Replied by steffan on topic Rocklobster
Mine did it a few months ago now just whilst I was board waiting for the better half to finish work killed the engine wiggled the lever then stared it back up again and it just slipped back in I don't no what happened or how I fixed it but its never happened since although I have since then changed the oil seals the oil and re greased the lever
- Johnniehec
- Thank you received: 56
13 years 3 weeks ago - 13 years 3 weeks ago #87802
by Johnniehec
Replied by Johnniehec on topic Rocklobster
Transmisson Windup?
Last edit: 13 years 3 weeks ago by Johnniehec.
- RichiesJimny
13 years 3 weeks ago #87810
by RichiesJimny
Replied by RichiesJimny on topic Rocklobster
I didn't grease the selector up when I fitted it i assumed the oil in the box would lubricate it I might try some grease, I don't think it's transmission windup as I get the problem moving between 4wd and 2wd even with the engine switched off.
- vitara_mad
13 years 3 weeks ago #87965
by vitara_mad
Replied by vitara_mad on topic Rocklobster
once you have got it back in 2wd will it go back to 4wd & back to 2wd again ???
- RichiesJimny
13 years 3 weeks ago #87972
by RichiesJimny
Moving from 2wd to 4wd is easy getting back into 2wd is a nightmare without even putting it in gear and driving it so it can't be transmission windup.
vitara_mad wrote: once you have got it back in 2wd will it go back to 4wd & back to 2wd again ???
Time to create page: 0.104 seconds
