Piston slap :-(
- 1sparky
24 Oct 2013 19:03 #87785
by 1sparky
Piston slap :-( was created by 1sparky
Hello ppl iv got a 1.3 16v single cam jimny and the engine has developed a noise after looking in to it iv found out its got very bad piston slap
so iv changed the engine last week with a secondhand engine, and now a week later and only covering about 100 mile boom piston slap again!!!!!!
What the hell is wrong with these engine and is this a common fault ????? Would love to hear from you all
- steffan
24 Oct 2013 20:07 #87794
by steffan
Replied by steffan on topic Piston slap :-(
Is it the g13 engine or m13 personaly I would have fitted a 1.6 after the first one gave up but hay ho each to there own
- Dave cc
24 Oct 2013 20:11 #87797
by Dave cc
Replied by Dave cc on topic Piston slap :-(
They aint the best in the world mate unless they have been looked after seem to suffer from the black gunge of death many have met there demise thru oil starvation to the cylider head looked after with regular oil changes they are good units.
How have you concluded that it is piston slap by the way ???
- Dave cc
24 Oct 2013 20:13 #87799
by Dave cc
Single cam :whistle:
steffan wrote: Is it the g13 engine or m13 personaly I would have fitted a 1.6 after the first one gave up but hay ho each to there own
24 Oct 2013 20:40 #87805
by Rhinoman
Replied by Rhinoman on topic Piston slap :-(
How many miles did the engines have on them? if the bores/pistons were that worn then I would also expect low compression and high oil consumption.
- 1sparky
24 Oct 2013 21:22 #87819
by 1sparky
Replied by 1sparky on topic Piston slap :-(
First engine has done 14700 miles and was chucking out lots off blue smoke,now it's out iv stripped it down and found the black gunk of death and piston one and two have a lot off piston slap, iv removed the oil rings of the piston and found all oil way blocked.
The engine in the jimny at the mo is making the same noise as the first so iv adjusted all the tappets listened to the block with a scope and hey ho seems to be the piston again, was told the engine has only done 47000 mile hmmmmm very hard miles more like
Time to create page: 0.171 seconds
