aproch angle
- deedar
22 Oct 2013 21:01 #87544
by deedar
aproch angle was created by deedar
I have just be reading and have seen something aboutvthe aproch angle some thing to do with front cross member and body mounts just wounderd what it is they do and is it worth it for a off road only truck which I am hoping to run a few trails when done any help will be great cheers
- JimnySweep
22 Oct 2013 21:44 #87554
by JimnySweep
Replied by JimnySweep on topic aproch angle
Approach angle is that which is possible to overcome on the approach to an object/obstruction (ie Jimny has approx 34 degrees) before the front end digs in stopping the front wheels getting traction to climb.
Remove bumper (or first thing that grounds on the approach) or increase the ground clearance may increase that angle?
Is that what you mean?
- deedar
22 Oct 2013 22:18 #87557
by deedar
Replied by deedar on topic aproch angle
I all ready have bumper removed and that removed and a 4.5 inch lift I was just wondering what people do when the do something with the front cross member and body mounts
- deedar
22 Oct 2013 22:21 #87559
by deedar
It says it has the front cross member and body mounts replaced to maximise aproch angle
23 Oct 2013 05:08 #87566
by facade
Replied by facade on topic aproch angle
Don't forget the back
It's all very well having an approach angle of 45 degrees, but if there is a towbar or something fitted that digs in and acts as a plough when the front wheels start to go up the slope you still won't climb it. :whistle:
- deedar
23 Oct 2013 06:51 #87572
by deedar
Back of thr truck is going to be choped of so there isno over hang what so ever
