Tyres
Can't really comment as I don't know those.Boltrabbit wrote:
just saw some 205/70/15 matador mp71 tyres on eBay around £260 for 4 are they any good should I be looking elsewhere!to be honest I don't want to pay much more than that for 4 tyres though :blink:
As a guide I paid 75 notes for my four used Yokohamas with 7mm tread and there were some new winter tyres which were nowt special for £190 for four. Bear in mind I am a cheapskate; whilst folks spend ooodles on tyres like £400, I don't.
Busta wrote: BFG Mud Terrains in 215/75 R15 will fit a standard pre-facelift Jimny with the front mud flaps removed, no scrubbing. They are £110 a corner though.
Yours were from Germany weren't they pal? Nice too.
- adamatdraycott
I run the General Grabbers AT2 and wouldn't change them (the AT2 was discontinued and replaced by the AT).
They will be cheaper than the BF Goodrich AT tyre and will definitely fill your arches nicely with no rubbing... unless you have the 2006-2012 front bumper
Cooper discoveries are also widely used, but not sure what sizes they come in.
- jonesyba420
one word springs to mind when matador tyres are mentioned,their about as budget as you get! well for normal cars they are.
You have to bare im mind that the only thing holding your car on the road is the tyres, why risk your life and others by fitting shi* tyres.
With expensive tyres your paying for more research and development aswell as better rubber, a £100 tyre will grip better and last longer than a £50 tyre. Is it worth saving £50 if the tyre lasts half the time.............no.
bfg at's are good for 90000miles apparently, hence their £110 a corner you get what you pay for regarding tyres IMO.
is a 215 75 15 bigger in diameter than a 195 80 15? I run 195 80 mt's and they get pretty close to the inside of the arch when flexing.
- Leathery1
215mm x 75% = 161.25mm
195 x 80% = 156mm
As I said earlier, 215 75s scuffed the mud flaps on standard suspension. Mud flaps off, no problem.
Tyre choice depends mainly on what you want to do with it. Bigger tyres, better ground clearance.
Bigger tyres, trim bodywork, lift suspension and possibly spend more on fixing CVs, but dont get grounded out as often!
