What battery are you using?
- Garry
14 Oct 2010 16:39 #5140
by Garry
What battery are you using? was created by Garry
I need to upgrade the battery in my jimny to be able to run the front winch i have put on,
What are you lot using?
14 Oct 2010 17:59 #5144
by kirkynut
Replied by kirkynut on topic Re: What battery are you using?
Numax 1000a cold cranking. I use it as my only battery and have found it absolutely ideal. We went to Slindon a few months ago and winched about 6 times in the day with not a hint of a problem.
Used it about 3 times in a few hours to winch at my local club recently, no problems.
It's ideal for simple recovery. For competitions I'd look at perhaps 2 of them and a second alternator.
You can get about 2 of them for the price of one of the popular winch batteries.
- Garry
15 Oct 2010 14:16 #5155
by Garry
Replied by Garry on topic Re: What battery are you using?
Sounds like a plan,
i know nothing about batterys, is there a model number or anything for the size dimensions i need?
i will eventualy get two of them, but the first will br a direct replacment for the standard,
also, will the standard battery terminals fit onto the Numax 1000a ?
sorry for all the quesrions, i just want to get it correct first time.
15 Oct 2010 18:06 #5178
by kirkynut
The top one on this page is the kiddie:
www.tayna.co.uk/Numax-Leisure-Batteries-S284-1.html
and Tanya are the people the get them from - first class service and delivery times.
As you can see from the dimensions in the spec it will not fit in your normalbattery tray so will need re-locating to the boot and you will need to get some very heavy duty cable to run on top of the chassis, attached by cable ties (I like cable ties) and bring it in via the drain hole in the boot.
You will also need some big terminals and a big crimper to attach them to the wires.
See here:
www.vehicle-wiring-products.eu/VWP-onlin...ble/batterycable.php
you want 50mm sq cable and these connectors - the CTT50's:
www.vehicle-wiring-products.eu/VWP-onlin...conns/batttermls.php
Place your winch and solenoid in roughly the right place and run string where you are going to route the wire, cut it and measure how much you used. That plus a bit extra is how much wire you need to order.
This solenoid extention kit is really useful too:
www.winchsolutions.co.uk/index.asp?actio...ts&catid1=1&catid2=4
but I have heard their isolators aren't up to long winch pulls.
Hope this helps
See here:
Hope this helps
15 Oct 2010 18:29 #5179
by kirkynut
This is the isolator switch I use:
cgi.ebay.co.uk/car-battery-cut-off-switc...&hash=item519096f08d
I got it at a local car parts shop for £5.99 as it was recommended by a good few people in my club who use them and have used the key types and melted them but have not yet melted one of these.
I does not come with any specs on the packaging so I just had to trust my recommendations and so far so good! I ought to carry a spare though in case I do have a problem.
- Garry
15 Oct 2010 18:44 #5180
by Garry
A huge thanks to you for the links and info,
theres a small problem of me mounting it in the boot
ill make a new battery tray on the passenger side of the engine bay,
ive already got a heavy duty isolator switch and the extended solenoid cables,
just need to get it all in and working and make up a loom to have in-cab controls to the winch
Time to create page: 0.142 seconds
