jimny steering lock
  • jimjimny
13 years 4 weeks ago #87195 by jimjimny
jimny steering lock was created by jimjimny
hi,new to the forum so be gentle with me :blush: ive just bought a jimny to do a bit of shooting and ive noticed its got more lock one side than the other,had a quick look underneath to see if there are any lockstops but could not see any? so how do I go about putting this right?
Ive noticed two steering arms with adj rods,one at the front and a longer one at the rear,I presume its one of these and if so which way do I adj it? jimny is on std suspension if that helps.
cheers
13 years 4 weeks ago - 13 years 4 weeks ago #87202 by facade
Replied by facade on topic jimny steering lock
First get both front wheels jacked up off the floor. Make sure that the car isn't going to drop on your hands, grasp each wheel at 12:00 and 6:00 and try and rock it off the car. If there is movement, get someone to press the brake pedal whilst you try again. If there is still movement, the king pin bearings need changing, no movement means wheel bearings.
Now look underneath and check the bar that joins the two wheels behind the axle (the tie rod) is straight.
Most likely it is bent. If it is, you need a new one, although you can straighten it.
Once the tie rod is straight, the tracking needs checking, to make sure that the wheels are pointing the right way to start with. (You can do this later)
Get in and wind the steering all the way to the left. Now wind all the way to the right, and count the turns. Now wind back half way. The wheels should point ahead.
If they don't, check the tracking now.
Before you mess with anything, it is possible that a cv joint has broken up and is stopping the wheel turning, so start the engine, and engage 4wd. (gear in neutral)
Turn the road wheel on the side that has no lock, and see if the wheel on the other side rotates the opposite way (it should) check for roughness, and see if the steering will move a bit further now. If it does, you need inspect the CV joints.
If it doesn't, adjustment is by altering the length of the drag link, the rod at the front from steering box to left hub. Unless someone has removed a lift kit it shouldn't need adjustment though, so I'd be looking for problems elsewhere first.
Anyway, there are two rusted solid locknuts (opposite hand threads) to undo, then the whole rod rotates to adjust the length, turn until the wheels point straight when the steering wheel is half way from lock to lock.
Last edit: 13 years 4 weeks ago by facade.
The following user(s) said Thank You: Busta, jimjimny
  • jimjimny
13 years 3 weeks ago #87221 by jimjimny
Replied by jimjimny on topic jimny steering lock
cheers for that,nothing looked bent and no play on the wheels,ile check the cv`s tomorrow and report back :)
13 years 3 weeks ago #87227 by facade
The steering won't go off centre on its own, something has happened.
Forgot to say to check the panhard rod from chassis to axle, if this is broken the axle moves sideways rather than steers, also bending it will pull the axle to one side and alter the steering.
  • jimjimny
13 years 3 weeks ago #87385 by jimjimny
back again :unsure: tried all the above and still cannot get full lock turning left,if I disconnect the steering I can its as if
its hitting a lockstop,ime wondering now if the hubs are bent? how many turns should it have lock to lock?
cheers
  • markyp2000
13 years 3 weeks ago #87395 by markyp2000
Replied by markyp2000 on topic jimny steering lock
Take the 2 track rod ends off the passengers hub and turn it by hand and look at the ball on the back of the hub and see if the seal goes to its mark it has made from years of movment then do it the otherside and see it thay move the same if thay do then ok if not then the hub that isnt going to were it should have have a broken cv or damaged cv joint or it may be that some one has changed the steerimg box and not put it to center before fitting as the lock stops are in the box
Time to create page: 0.101 seconds
