Body Lift
  • Lukeavb
20 Oct 2013 10:15 #87167 by Lukeavb
Body Lift was created by Lukeavb
My jimny has no lift at the current time, when i offroad my wheels rub on the body work on the arches, but only on the bumper not the inner arch, this happens when going up or down steep hills and also in full lock, not seen many jimnys with their arches ground out so just wondering if a body lift would help the clearance abit, and also what are the downsides to a body lift? I've heard the lift blocks can pop out but this is the cheaper option other than getting a lift kit. also are they hard to install?
Thanks guys, hope you can help.
  • jonesyba420
20 Oct 2013 10:23 #87168 by jonesyba420
Replied by jonesyba420 on topic Body Lift
Im no expert but I dont see how they could pop out as you jack the body up and replace the current block with new taller ones, there fitted with a bolt through the middle hence I dont see how they could pop out.
you need to be able to lift the body up off the chassis and I belive you may need to extend a few things.
  • Wiltec17
20 Oct 2013 11:30 #87171 by Wiltec17
Replied by Wiltec17 on topic Body Lift
Lukeavb wrote: My jimny has no lift at the current time, when i offroad my wheels rub on the body work on the arches, but only on the bumper not the inner arch, this happens when going up or down steep hills and also in full lock, not seen many jimnys with their arches ground out so just wondering if a body lift would help the clearance abit, and also what are the downsides to a body lift? I've heard the lift blocks can pop out but this is the cheaper option other than getting a lift kit. also are they hard to install?
A suspension lift with spacers rather than springs is a cheap option worth looking at. Won't improve articulation but should help with clearance issues (same as a spring lift) without taking a hacksaw to your bumpers (plus they look so much better lifted ;))
We fitted a set to my cousins jimny yesterday, il let you know he gets on with it once we've had chance to put it through its paces.
Don't forget to budget for castor correction though.
Time to create page: 0.164 seconds
