Alternators outputs
- Wiltec17
13 years 1 month ago #86577
by Wiltec17
Alternators outputs was created by Wiltec17
Is there a difference in alternator outputs on the later model jimnys and would they be compatible with a single cam engine if removed from a twin cam?
I Only ask as I would like to upgrade the alternator to deal with the extra electrical bits that are going on the Jimny.
I know of a 06 plate jimny with air con (electric fan) and wondered if they fitted a higher output altenator on them to suite.
Could be a cheap upgrade if it's compatible.
Cheers
Cheers
- vitara_mad
13 years 1 month ago #86604
by vitara_mad
Replied by vitara_mad on topic Alternators outputs
grand vitara 2.5v6 alternator
- jonesyba420
13 years 1 month ago - 13 years 1 month ago #86606
by jonesyba420
Replied by jonesyba420 on topic Alternators outputs
mentions Jimny in the listing.
Last edit: 13 years 1 month ago by jonesyba420.
- mudman
13 years 1 month ago #86636
by mudman
Replied by mudman on topic Alternators outputs
I use a baleno 1.8 gtx alternator puts out 90amps instead of the jimnys 70amps
- Jimny J
13 years 3 weeks ago #87600
by Jimny J
Replied by Jimny J on topic Alternators outputs
Anybody got any part numbers or a little more in the way of engine codes? Just been too my local unipart enquiring about other alternators and on their system the above mentioned parts are still only 70amp output. Im going through a fan/alternator belt every 2 to 3 months. Getting a bit fed up... All I have fitted electrics wise is a Kenwood amp running a single 12in sub, yet from a cold start the belt will slip and squeal for a good 10-15 minutes. Its made worse at night if its wet out, presumably from the wipers and de-mist. Ive had the alternator refurbed and all new brackets fitted and the issue is still there.
- mudman
13 years 3 weeks ago #87677
by mudman
ebay number 190585469271 that the one I brought
Time to create page: 0.090 seconds
