Dodgy heater switch or something else?
  • minibbb
13 years 1 month ago #86501 by minibbb
The heater switch on my 2005 jimny is playing up, sometimes when I slide it across the heater won't come on and I have to switch on and off to get it to work or only blows on max setting.
The heat does blow out hot so I'm guessing maybe just the switch is faulty. Is it easy to swap out the heater control panel?
  • markyp2000
13 years 1 month ago #86549 by markyp2000
Replied by markyp2000 on topic Dodgy heater switch or something else?
If it only works on top speed id say it was more lilly to be the heater resistor
  • minibbb
13 years 1 month ago #86592 by minibbb
Replied by minibbb on topic Re:Dodgy heater switch or something else?
markyp2000 wrote: If it only works on top speed id say it was more lilly to be the heater resistor
Thanks mate, It's very hit and miss tbh, sometimes only top speed but other times only the middle one. Is the resistor an easy fix?
  • markyp2000
13 years 1 month ago #86631 by markyp2000
Replied by markyp2000 on topic Re:Dodgy heater switch or something else?
Should be in the heater box some where i think its behind the glove box it could be a switch playing up take it out see if you can take it apart and clean it up
Time to create page: 0.082 seconds
