G13BB Starting problem - does not keep REV.
  • Verbeeck
14 Oct 2013 19:09 #86220 by Verbeeck
Replied by Verbeeck on topic G13BB Starting problem - does not keep REV.
No loose pipes, everything seems ok, before changing coil i also noticed the engine was heating in traffic and fuel cunsumption very high, about 240 km a full tank. Had to push the engine to 4k 4.5 k rpm in order to drive at least 60km/h
  • markyp2000
15 Oct 2013 17:47 #86372 by markyp2000
Replied by markyp2000 on topic G13BB Starting problem - does not keep REV.
So it may be the crank shaft sensor at fault as well or it may be the wrong cam shaft sensor
15 Oct 2013 20:40 #86400 by Rhinoman
Have you done a compression test? when was the fuel filter changed last? I would also remove the O2 sensor and see if it improves, it could be a blocked cat.
  • Dave cc
15 Oct 2013 21:01 #86406 by Dave cc
Replied by Dave cc on topic G13BB Starting problem - does not keep REV.
also noticed the engine was heating in traffic and fuel cunsumption very high, about 240 km a full tank. Had to push the engine to 4k 4.5 k rpm in order to drive at least 60km/h[/quote]
Could this be a clue loosing compression head gasket faliure poss
  • Verbeeck
29 Oct 2013 10:46 #88446 by Verbeeck
hi, how to change fuel filter?
Time to create page: 0.098 seconds
