Free Wheeling Hubs
- auchenblae
- Elite Member
- Thank you received: 25
13 years 1 month ago #85598
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Free Wheeling Hubs was created by auchenblae
Say after 4 miles or so noise from the nearside hub. Put it into 4WD and it goes away. Then 2WD and it is fine.
I changed the king pins bearings in that hub three years ago and this has happened off and on for a while.
So it seems that it may be half engaging the hubs that is maybe causing the noise.
Is the default no vacuum and no front wheel engagement. Then 4WD is vacuum and the hubs engaged.
Tying to think what would cause the hubs to sort of start engaging.
Run the 99 car for 8 years and 100k before getting rid and still a good sump. This 07 car has a porous sump, just ordered the bits with VAT, sump £114 plus gasket and stud £6. The parts guy said they are selling lots of sumps.
At least it is in stock at Suzuki.
eddie
eddie
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
13 years 1 month ago - 13 years 1 month ago #85610
by Busta
Replied by Busta on topic Free Wheeling Hubs
There's a guide to how the hubs operate and what to check here:
www.bigjimny.com/images/documents/Check_the_vacuum_system.pdf
Last edit: 13 years 1 month ago by Busta.
The following user(s) said Thank You: helijohn
13 years 1 month ago #85858
Nice link. I confess I have learned more tonight. Now to store it.
Replied by helijohn on topic Free Wheeling Hubs
Busta wrote: There's a guide to how the hubs operate and what to check here: www.bigjimny.com/images/documents/Check_the_vacuum_system.pdf
Time to create page: 0.087 seconds
