ICV
  • DaveJ
06 Oct 2013 07:29 #85291 by DaveJ
ICV was created by DaveJ
Hi again, thanks for everyone's suggestion regarding my last post (reference warped hubs) now need more help to identify and locate the ICV on a 2000 Jimny Soft-top. I have been told its the item sitting on the inlet manifold at the point closest to the bulkhead but it look absolutely nothing like the ICV image that I have googled.
All comments and ideas appreciated!
Thanks in advance.
  • dirtydogz
06 Oct 2013 13:42 - 06 Oct 2013 13:42 #85304 by dirtydogz
Replied by dirtydogz on topic ICV
The idle air control valve is fitted to the bottom of the throttle body at the front of the engine as in the photo.
Last edit: 06 Oct 2013 13:42 by dirtydogz.
  • justjimmy
06 Oct 2013 16:09 #85314 by justjimmy
Replied by justjimmy on topic ICV
To test its working you can just unplug it with the engine runnig and see does it idle up. Mine wouldnt idle correctly so I cleaned the throttlebody with a rag and my finger. The gunk and oil around the butterfly was not letting enough air past at idle. A can of carb cleaner made the job easier. Youtube is a great place to find instrutcions if u are not mechanicaly minded.
