Broken 4WD help ??!
- Dave91
05 Oct 2013 17:44 #85252
by Dave91
Broken 4WD help ??! was created by Dave91
Hello everyone! i'm new to this site and to offroading. I have a slightly modified 03 jimny (will post pics later) and I managed to get stuck in a bog today. There was a nasty clunk noise then I lost drive to the front wheels. Luckily somebody was just passing in a vitara and pulled me out because I wasn't getting anywhere in rwd. He seemed to think ive snapped a half shaft?? does this sound right? what sort of money am I looking at to fix etc etc
Any help or advice would be appreciated.
05 Oct 2013 17:53 #85254
by facade
Replied by facade on topic Broken 4WD help ??!
Possible, more likely a broken CV joint.
Either way the hub has to come off to pull the halfshaft out, with CV joint.
Usually the shortest one breaks first.
It is also possible to break the differential, again the half shafts need to come out to remove it.
- Dave91
05 Oct 2013 18:08 #85255
by Dave91
Replied by Dave91 on topic Broken 4WD help ??!
Does the CV joint come separate from the half shaft? or would I need to buy the whole thing? sorry if this is a dumb question, the 4x4 world is new to me. fingers crossed its not a broken differential that sounds expensive!
- markyp2000
05 Oct 2013 19:12 #85257
by markyp2000
Replied by markyp2000 on topic Broken 4WD help ??!
Where are you located some one may live near you who would be willing to help
- Dave91
13 Oct 2013 13:28 #86038
by Dave91
Ive had both shafts out today and they both seem fine, not that i really knew what I was looking for but all the splines were ok and if i turned the shaft by hand it turned at the cv end. Does this mean the diff is goosed? something I did notice was with all 4 wheels off the ground and in 4wd with the hubs off I could see the shafts turning but when the wheels are on they dont turn :S could this be the hubs not vacuming properly?? sorry again if I sound like an idiot but im not a mechanic. Any help or theories would be good thanks
13 Oct 2013 18:25 #86083
Stands a good chance especially as the vac hub system seems to be one of the Jimny's regular weaknesses. The newcomer to the Jimny (and maybe 4x4s) could very well be foxed. Keep asking the questions, it's what the forum is for!
Replied by helijohn on topic Broken 4WD help ??!
Dave91 wrote: could this be the hubs not vacuming properly?? sorry again if I sound like an idiot but im not a mechanic. Any help or theories would be good thanks
Time to create page: 0.208 seconds
