Input needed on hardcore Jimny
02 Oct 2013 20:49 #85011 by Rhinoman
Its electronically controlled, the TCM has no idea if you've changed the engine so it will continue to change on its programmed settings.
  • peterand
02 Oct 2013 20:57 #85014 by peterand
Replied by peterand on topic Input needed on hardcore Jimny
One of the input parameters to the TCM is Trottleposition and that is feed via the ECM
  • Dave cc
02 Oct 2013 21:09 - 02 Oct 2013 21:10 #85017 by Dave cc
Replied by Dave cc on topic Input needed on hardcore Jimny
peterand wrote: Hi everyone, I'm old in the offroadgame but new to Jimny. For a change I will try to buidl and drive a small car B) Previously I have enjoyed Grand Cherokees, TLC BJ75 and MB G.
Just bought a -02 with automatic, full stock that I will convert over the winter. It will be a combined Challange / Offroad vechicle, roadlegal but it will just be used for play. I don't mind fabbing parts and cutting in the car.
The whishlist so far
Lockers front and rear. Rear will be either lockright or welded. Front ARB
33" Tires on bedlock rims. MT2 or KL71 or Simex
4-5" lift + 2" bodylift
Cutout wheelhouses
Vinch front and rear
External cage
Steelbumpers front and rear.
some kind of rockcrawler gearing
I guess i will need to invest in stronger driveshafts and CVs etc as well
I would really like some input on primary
1. the Lift, what to buy? Springs, Radius, Panhards, shocks etc What brand is best (highest quality)?
2. Axle upgrades ?
3. Gearing ?
Of course I wellcome all inputs :)
Regards rom Sweden
Throw away you axles and just fit somthing stronger by the time you have fitted all the guts you will have spent a lot of money and will all still be wrapped up in a choclate axle case
Last edit: 02 Oct 2013 21:10 by Dave cc.
03 Oct 2013 08:12 #85052 by Obarno
I've got an auto Jimny with a rocklobster transfer box and 235x75x15 Tyres. When Il first drove it after the pconversion the auto box was 'confused'! It didnt change gear at the right time and was not good to drive. Clearly the gearbox also needed a speed sensor input. The speedo was way out and when I fitted an electronic controller to correct it, the gearbox also behaved as it should. So you should definitely include this as part of the mods.
04 Oct 2013 20:56 #85210 by kirkynut
Obarno wrote: I've got an auto Jimny with a rocklobster transfer box and 235x75x15 Tyres. When Il first drove it after the pconversion the auto box was 'confused'! It didnt change gear at the right time and was not good to drive. Clearly the gearbox also needed a speed sensor input. The speedo was way out and when I fitted an electronic controller to correct it, the gearbox also behaved as it should. So you should definitely include this as part of the mods.
Tell us more about the electronic controller to correct the speedo.
05 Oct 2013 11:57 #85233 by Obarno
Martin told me about Jaycar electronics who, amongst others, produce an electronic speedo corrector. The Jaycar one comes as a kit of parts that have to be soldered together onto a board they supply. Its a complete kit with full instructions and all components. You need also to buy a box to contain it, which Jaycar can supply. Here is the link for the kit
www.jaycar.co.nz/productView.asp?ID=KC5435
I bought one and a friend put it together for me. Its fully adjustable over a huge range of variations. It has 4 wires connected to it, a live and neutral, and an 'in and out' from the speedo sensor on the transfer box. I cut the original wire from the sensor and extended it to and from the corrector, and also used the live and neutral to power the corrector. Once set it remains unchanged. I used a gps to set the speed on it. All of this was for my auto Jimny.
I also have a VVT that I have changed the transfer box, diffs, tyres etc and had the same problem in that the speedo was incorrect. I bought another kit for that which has also worked without problem. This kit also drives a Brantz Rally trip for Road Book type events.
There are several companies in America that supply ready made units which saves the problem of soldering it.
