2008 1.3 vvt camshaft sensor position
  • jonesyba420
21 Sep 2013 16:14 #83906 by jonesyba420
Replied by jonesyba420 on topic 2008 1.3 vvt camshaft sensor position
Just had a look on the thread I posted on when I did my crank sensor and it says I undid the top 2 bolts.
  • boazbd
21 Sep 2013 16:15 #83907 by boazbd
Replied by boazbd on topic 2008 1.3 vvt camshaft sensor position
Thanks, I'll try that!
  • jonesyba420
21 Sep 2013 16:21 #83909 by jonesyba420
We're here to help or atleast try to.
Let us know how you get on.
22 Sep 2013 00:34 #83952 by facade
I could not get that allen bolt to move on mine either :dry: and using a prybar to rotate the alternator needed so much force I really felt that the alloy casing was about to shatter.
To cut a long story short, I ended up removing the radiator, then unbolting the alternator support bracket from the engine to take the whole lot into the garage where it came undone once I got proper tools to it.
Can't remember why moles wouldn't clamp on in situ with the radiator out, but if they would have I wouldn't have taken the whole bracket off :lol: With the radiator out I was able to get a good fitting hex key socket in the bolt, and use enough force to simply make the hexagon hole perfectly round without anything else happening :whistle:
The other end of the bolt is into a welded on nut on the back of the bracket, so even though you can get a socket to it, you can't turn anything.
Time to create page: 0.317 seconds
