2008 1.3 vvt camshaft sensor position
- boazbd
20 Sep 2013 12:22 #83778
by boazbd
2008 1.3 vvt camshaft sensor position was created by boazbd
Hello all,
It seems I have the same problem as many have already stated here on the forums, which relates to the
camshaft/crankshaft sensor/s being faulty.
I've located the crankshaft easily between the alternator and the engine block but I can't seem to find the what most people regard
as easy to find camshaft sensor. As far as I've seen here on the forums it should be located on the front right of the engine block but I can't find it.
All I see there is a blueish connector with two wires but I don't see the distinctive shape of the camshaft sensor.
I'm attaching photos...
Any help would be appreciated.
Thanks,
Boaz.
Thanks,
Boaz.
20 Sep 2013 18:35 #83796
by facade
Replied by facade on topic 2008 1.3 vvt camshaft sensor position
That must be it, behind the silver pipe with the blue connector.
It has to face the cam sprocket, so it is in the right place, it must unbolt and pull out forwards.
I think this is it, but I'm looking at a photo of a VVT, I've never seen one.
- boazbd
21 Sep 2013 13:52 #83894
by boazbd
Replied by boazbd on topic 2008 1.3 vvt camshaft sensor position
Hi facade,
I guess you're right about the sensor's position. This is what I was also thinking, I was hoping someone who has the same engine
could confirm that.
Anyways,
1. does anyone has access to the Suzuki EPC and can tell what are the part numbers for the cam and crank sensors?
2. While trying to get to the crank sensor I had difficulty undoing the alternator's hinge screw. It's an Allen screw as far as I can tell.
Any tips?
Thanks,
Boaz.
could confirm that.
Anyways,
Any tips?
Thanks,
Boaz.
- jonesyba420
21 Sep 2013 14:23 #83896
by jonesyba420
Replied by jonesyba420 on topic 2008 1.3 vvt camshaft sensor position
Ive got a sneaky suspition you dont need to undo the allen key bolt just the 2 at the top. Not 100% positive tho.
- boazbd
21 Sep 2013 15:46 - 21 Sep 2013 15:47 #83902
by boazbd
The service manual says that you should undo one of the bolts at the top (the one in a track) and the allen one that seems to be the pivot bolt. Can anyone confirm this?
Last edit: 21 Sep 2013 15:47 by boazbd.
- jonesyba420
21 Sep 2013 16:03 #83904
by jonesyba420
Im pretty sure when I did mine I had the same issue of not really being able to geto the allen key bolt so undone the top 2 bolts and I swang away fine.give it a go if it still wont move you ain't lost anything and if it does problem solved
Time to create page: 0.148 seconds
