No ignition
- Baumann
19 Sep 2013 20:30 #83728
by Baumann
No ignition was created by Baumann
Hi
After welding some body work on my Samurai the ignition died.
There is no spark when turning the engine.
It constantly blows the fuse.
Im thinking that the ignition coil/distributor is dead.
My problem is that the ignition coil/distributor is not the original one, and I have no idea what model it comes from, and my local sparepart dealer cant help.
I have added a picture of it, any information or help is highly appriciated.
- markyp2000
19 Sep 2013 20:52 #83736
by markyp2000
Replied by markyp2000 on topic No ignition
Did you not disconect the battery
Also what fues keeps blowing where you welded was there any wires near by that could have melted
- Baumann
20 Sep 2013 08:31 #83761
by Baumann
Replied by Baumann on topic No ignition
Yeah I forgot to disconnect the battery. I cant see that I have melted any wires.
When I turn the engine it blows a fuse. I guess its the fuse for the ingnition coil.
Thats why I assume that the ingnition coil is dead, but since its not the standard ignition coil I cant find a new one.
Normally ignintion coil and distributor is 2 separate units, but here its build into 1 unit.
- gilburton
20 Sep 2013 09:06 - 20 Sep 2013 09:22 #83762
by gilburton
Replied by gilburton on topic No ignition
I've done a quick check on the internet and I can't find any reference to a similar distributor??
I notice you say the car is a Samurai??
Are you in the UK??
The Jimny wasn't called a Samurai in the UK so possibly this is a local market model?
Some more detail might help eg exact car/cc/year etc. or some pics of the car/engine.
In the UK the Samurai was the SJ 410/413 if that's any help?
The other option is that something non standard has been fitted?
Just a thought on the fuse blowing. Are you sure that it's the ignition fuse??
I presume you had the ignition turned off when welding so my first thoughts would be to check all the wires between the battery,starter and ignition switch.
If simply turning the ignition on doesn't blow the fuse but operating the starter does blow it I would check the starter circuit/wires first.
Are you in the UK??
Last edit: 20 Sep 2013 09:22 by gilburton.
- markyp2000
20 Sep 2013 09:33 #83765
by markyp2000
Does it blow the fues with the ignition syetem unpluged
- Baumann
20 Sep 2013 15:41 #83783
by Baumann
Sorry, I totally forgot to write some details about the car.
Its a Samurai SJ413 from 88, 1.3L engine.
Im from Denmark.
It doesnt blow the fuse when I set ignition on, but when the starter turns the engine.
Im from Denmark.
