32mm wheel spacers.
  • j bolan
13 years 2 months ago - 13 years 2 months ago #82240 by j bolan
32mm wheel spacers. was created by j bolan
Is it ok to fit wheel spacers to a jimny.i like the look of the wider wheel stance.would it harm the wheel bearing etc.i have alloy wheels with 215/75/15 tyres fitted.
Last edit: 13 years 2 months ago by j bolan. Reason: more info
  • GuardianAngel
13 years 2 months ago #82246 by GuardianAngel
Replied by GuardianAngel on topic Re:32mm wheel spacers.
It will act as a lever on the bearings as the wheels are further out, but with wider tyres it might be less of a problem, as the extra width is bought inwards towards the bearing.
  • jonesyba420
13 years 2 months ago #82247 by jonesyba420
Replied by jonesyba420 on topic Re:32mm wheel spacers.
All depends how good the bearings and other components are. My first car was a K reg clio which I fitted with 15inch alloys (back when I was a youngen) the car handled like a beast but I used to go through wheel bearings at an alarming rate due to the extra load (in the 2 yrs I had it probably replaced 6 wheel bearings), on my other car (ibiza turbo) which ive had 5 odd years with spacers fitted has never had any issues with bearings etc. Better quality car and components.
Fitting spacers to a jimny will encourage you to drive in defender width rutts risking grounding out and potentially doing considerable damage, f*#× the spacers and straddle the rutts like a sensible offroader should.
Just my 2p's worth.
  • whizz3006
13 years 2 months ago #82308 by whizz3006
Replied by whizz3006 on topic 32mm wheel spacers.
I stuck my 32mm spacers on a few months back and love the new look and feel...... and if it means new bearings now and again I don't care! :laugh:
www.bigjimny.com/index.php/forum/8-my-jimny/50163-goldmember
13 years 2 months ago #82314 by Busta
Replied by Busta on topic 32mm wheel spacers.
There's a good chance you'll get scrubbing issues with spacers and 215/75 tyres, unless you've lifted the suspension. Personally I wouldn't bother.
The following user(s) said Thank You: j bolan
