JIMNY FLEX
- TomDK
04 Sep 2013 00:36 #82089
by TomDK
yup
The C/C bushes you've got are good for a 2" lift or something similar. Of course they're still better than nothing on a 80mm lift. But to get the castor angle 100% right again, you'll need C/C radius arms
Replied by TomDK on topic JIMNY FLEX
Jimny_Aus wrote: Ahh so the arms add more correction that just normal bushed, i think they where 3° offset....
yup
- Jimny_Aus
04 Sep 2013 00:55 #82090
by Jimny_Aus
Replied by Jimny_Aus on topic JIMNY FLEX
spose i better start saving then. thanks for your help mate
04 Sep 2013 04:28 #82094
by kirkynut
Replied by kirkynut on topic JIMNY FLEX
You should.have plenty of flex then. Are you trying hard enough?
- Jimny_Aus
04 Sep 2013 06:32 #82100
by Jimny_Aus
YEA IN MY PROFILE PIC, THE BACK WHEEL IS OFF THE GROUND
04 Sep 2013 17:47 #82160
by kirkynut
Hell, that picture's tiny, I can't see from that! It takes a bit more for flex that taking the ground from under one wheel, the front on that side, from what I can see is holding the car level, so unless the other side's rear wheel gets pushed up more this side can't droop more.
I say there's nought wrong with your suspension, you just ain't been in the right circumstances yet.
Go and drive one front wheel up a big ramp or concrete block so it's a couple of feet higher than the others and it won't drive anymore cos it's cross axled!
Look on the Bigjimny shop at Jimny suspension to see me doing this. I damn near got stuck and had to push the bugger off the concrete block by hand!
Jimny_Aus wrote: YEA IN MY PROFILE PIC, THE BACK WHEEL IS OFF THE GROUND
- jonesyba420
04 Sep 2013 17:57 #82161
by jonesyba420
Replied by jonesyba420 on topic JIMNY FLEX
Will caster corrected radius arms make any difference to flex?I thought it was to correct steering.
Time to create page: 0.096 seconds
