question regarding 4wd.
- jonesyba420
So my question is how wet does the road have to be for you to be able to use 4wd without the risk of snapping shafts etc?
- JivingDaddy
I use 4WD high only when there's snow and/or ice on the road and only when it's thick on the road. The road has to have some slip in it and the rain would have to be really heavy and deep on the road or you will **** up the transmission. As soon as I get on a main road that's quite reasonable I go straight back to 2WD. 4WD high is also OK on wet grassy lanes. As I said, only if the surface has some slip in it.
4WD low = serious off road stuff.
- jonesyba420
I agree Ill only use 4wdh when I cannot progress any further in 2wd, 4wdl is only really for slow controlled driving over difficult terrain.
I hope we get some more views as it'll help newbies.
- UKDAN
Dan
- TomDK
jonesyba420 wrote: Random question coming up, I know your not meant to use four wheel drive on the road as it winds up the transmission when cornering which will potentially break things therefor it should only be used when on loose surfaces mud etc, but upon reading the info on my sunvisor again (sat in town bored waiting for my misses) it says "use 4wd position for offroad driving or on slippery roads ( wet, snow-covered, muddy etc)".
Cornering does not affect the transmission since there's a diff front and rear.
- markyp2000
