panard rod.
  • jonesyba420
13 years 2 months ago #81402 by jonesyba420
panard rod. was created by jonesyba420
Can I remove the panard rod at the back with the car on its wheels? Painting the back axel so want to take it off for better access if possible.
  • Reckerr
13 years 2 months ago #81403 by Reckerr
Replied by Reckerr on topic panard rod.
I did. But mine was bent so putting it back on I had to jack it to move the axle a little left/body a little right.
  • jonesyba420
13 years 2 months ago #81405 by jonesyba420
Replied by jonesyba420 on topic panard rod.
The car will be up on jackable car ramps at the back so I can easily get under it to paint it so can I just simply take the panard rod off paint all around it then put it back on without having any issues? If ive gotta mess around re alligning things ill just struggle round it.
  • ChrisM
13 years 2 months ago #81421 by ChrisM
Replied by ChrisM on topic panard rod.
There may be some tension in it, but nothing will collapse when its removed. But you may need some additional help to push the body sideways to put it back on depending if the axle/body moves left or right a bit, just to line up the bolt holes to get the bolt back in. Of course if your jacking up the body to paint the axle then you should be able to do it yourself with the axle hanging down to swing it.
  • jonesyba420
13 years 2 months ago #81424 by jonesyba420
I wont be jacking the body up as my ramps go considerably higher than my trolly jack. Ill just whip it off and see how it goes.
  • markyp2000
13 years 2 months ago #81426 by markyp2000
Replied by markyp2000 on topic panard rod.
Put it on ya ramps the mesure from the inner side of the wheel to the chassis both sides and if you have any wood lying around cut it to size and wedge it in to stop it moving
