Alloy wheel nuts 60°
  • helijohn
28 Aug 2013 10:07 #81272 by helijohn
Alloy wheel nuts 60° was created by helijohn
These measure 60° so I assume they will be OK for alloys - am I right? They go in nicely and the wheels are Smith's.
  • markyp2000
28 Aug 2013 11:25 #81283 by markyp2000
Replied by markyp2000 on topic Alloy wheel nuts 60°
Thay are similar to the alloys i had your best off getting 17mm nuts so you can get a good impact socket on there mine kept coming lose as i couldnt torque them up right just keep an eye on them and make shore thay stay tight
  • helijohn
28 Aug 2013 20:09 #81339 by helijohn
Replied by helijohn on topic Alloy wheel nuts 60°
markyp2000 wrote: Thay are similar to the alloys i had your best off getting 17mm nuts so you can get a good impact socket on there mine kept coming lose as i couldnt torque them up right just keep an eye on them and make shore thay stay tight
Thanks, they seem OK but next pension day I might get a set of longer ones. :laugh:
  • helijohn
29 Aug 2013 06:36 #81393 by helijohn
markyp2000 wrote: your best off getting 17mm nuts so you can get a good impact socket on there
Do you mean 17mm AF cos they are that. I never use an impact wrench (except to remove the nuts) ; I torque mine down! ;)
  • markyp2000
29 Aug 2013 08:14 #81398 by markyp2000
No i mean 17mm if it was AF it would be 11/16 of an inch
  • helijohn
29 Aug 2013 10:43 #81420 by helijohn
markyp2000 wrote: No i mean 17mm if it was AF it would be 11/16 of an inch
I got it wrong - it was 19mm
AF means across flats so you can have 17mm AF and 19mm AF.
Time to create page: 0.113 seconds
