No spark after engine swap
- roverp5b
13 years 2 months ago #81187
by roverp5b
No spark after engine swap was created by roverp5b
Hi everyone, a long time browser but recent joiner here, as I need some help! Bit rich I know, being my first post 'n all, but promise to try harder in the future!
Anyway, the problem is as the title. I have a 1998 hard top Jimny with a g13bb engine, sadly with a cracked block. I managed to get a low mileage g13bb engine from a 2001 or 02 soft top. Engine is in, complete with manifolds, injectors etc, and everything connected up. I haven't seen any differences between the two engines.
It now won't start, and it appears it isn't sparking. I have rechecked the connections and even tried the coil packs off the original engine, to no avail. Any ideas clever people?
- barnes
13 years 2 months ago #81188
by barnes
Replied by barnes on topic No spark after engine swap
Dont quote me but i think the soft top has something different with cam/crank sensors sure someone will be able to shed some light on this
- markyp2000
13 years 2 months ago #81190
by markyp2000
Replied by markyp2000 on topic No spark after engine swap
Take the rocker cover off and on the rear end of the cam shaft should be a target for the cam sensor make shore thay are the sam if not swop the cams over and readjust the tappets
- Cider
13 years 2 months ago #81214
by Cider
Replied by Cider on topic No spark after engine swap
Yep my moneys on the cam shaft not being the same
Hard top have 11 pick up lobes on the sensor ring
Soft top has 2 pick up lobes on the sensor ring + "a crank sensor which you do not need if fitting into a hard top"
13 years 2 months ago #81245
by j999pre
Grey pick up Jimny
Replied by j999pre on topic No spark after engine swap
I agree, after you have swapped the cam also check the earth on the front of the engine and down near the starter.
Grey pick up Jimny
- markyp2000
13 years 2 months ago #81251
by markyp2000
And the silly earth on the rear of the head near the camshaft sensor
Time to create page: 0.091 seconds
