OBD CAT ??
- Gromit
26 Aug 2013 18:53 #81082
by Gromit
OBD CAT ?? was created by Gromit
So I need to get a new Catalytic converter for the Jimny, what does all this with or without OBD mean ??
26 Aug 2013 19:18 - 26 Aug 2013 19:20 #81090
by facade
Replied by facade on topic OBD CAT ??
Most likely it refers to the presence or absence of the post-cat oxygen sensor.
The early engines only had one sensor, on the exhaust manifold, the later engines added a second at the rear of the catalyst.
If there are wires coming from the rear of the catalyst you have the later type.
(There is a threaded bush on top of the catalyst, you need to remove your sensor and fit to the new catalyst.)
Last edit: 26 Aug 2013 19:20 by facade.
- Dave cc
26 Aug 2013 19:18 #81092
by Dave cc
Replied by Dave cc on topic OBD CAT ??
OBD is on board diagnostics saying that thought all jimnys being fuel injected had ODB1 or OBD 2
- Gromit
26 Aug 2013 19:47 #81103
by Gromit
Replied by Gromit on topic OBD CAT ??
Cheers guys, yes it has a sensor at the year of the Cat . Still a confusing load of cats to choose from on Ebay ??
Mine is a 2002 (51 plate) M13A engined car.
26 Aug 2013 23:15 - 26 Aug 2013 23:17 #81143
by facade
Nah, looks like only two types to me
1) 70 quid one one: no threaded sensor bush
2) 100 quid one: has sensor bush
guess which type I need
EDIT: there is a third type, which won't fit as there don't seem to be any pipes or flanges.
I'd buy the one that comes with the bolts and seal rings from the supplier who claims they are the cheapest and will beat any price like for like.
Last edit: 26 Aug 2013 23:17 by facade.
- Gromit
27 Aug 2013 05:59 #81150
by Gromit
