No Heat (problem) ?? Help PLEASE
- Dunnin21
24 Aug 2013 19:09 #80945
by Dunnin21
No Heat (problem) ?? Help PLEASE was created by Dunnin21
Being out on my first laning trip today with a few of the boys. On way back its was raining as per usual in the NE, and went to use the heaters to demist the window. The actual blower was OK 3 setting work fine, but with the temperature control pushed to high there was no heat. I check the cabin filter in case this was blocked but it was missing so cant be that. Does any one no were i can start or a possible solution maybe thing to check. Any help would be much appreciated thanks Andy
24 Aug 2013 19:19 #80947
by j999pre
Grey pick up Jimny
Replied by j999pre on topic No Heat (problem) ?? Help PLEASE
Down by your clutch foot, little white cam operates the flaps in the heater box. This can get kicked and damaged, check cable operation to it too. Did the engine get up to temp?
Grey pick up Jimny
- Dunnin21
27 Aug 2013 19:42 #81211
by Dunnin21
Replied by Dunnin21 on topic No Heat (problem) ?? Help PLEASE
Hi, got it in one the wire cable had come off, cable tie fixed the job thanks
- gaz3359
27 Aug 2013 21:51 #81231
by gaz3359
Replied by gaz3359 on topic No Heat (problem) ?? Help PLEASE
A hem :whistle:
28 Aug 2013 08:04 #81254
by j999pre
Sometimes the easy fixes are the most satisfying. Nice job
Grey pick up Jimny
Dunnin21 wrote: Hi, got it in one the wire cable had come off, cable tie fixed the job thanks
Grey pick up Jimny
Time to create page: 0.162 seconds
