Brake pipe clips
- Thank you received: 671
24 Aug 2013 12:37 #80909
by facade
Brake pipe clips was created by facade
I need to change the pipes under the Jimny this year.
I have the pipe, and am resigned to dropping the tank for access, and to do the 3 fuel pipes.
All the pipes are held so neatly with some plastic combs.
What holds them on?
The manual gives a tightening torque that could only be fo a steel bolt, but I cant see a bolt anywhere.
It looks as though they might pop over a shaped bolt. Without breaking one I can't tell.
I'm going to need new ones, as they are bound to break when I try and take the pipes out, anyone know the part numbers? (and a likely price: if they are £20 each I'll cut the pipes into 6" pieces and leave them on the car
There seem to be 2 tall ones and 4 short ones, for a total of 7 in the manual, so there must be 1 I can't see somewhere.
What holds them on?
24 Aug 2013 13:15 #80916
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Brake pipe clips
I think they pop over a stud like you say.
Grey pick up Jimny
24 Aug 2013 14:06 #80918
by facade
Replied by facade on topic Brake pipe clips
I'm thinking that, and I might make up something to pop them off.
The pipes push in from the back, and the clip springs out over them, so they wont come out.
Easiest would be to buy a new set.
I called into the local suzuki dealers, to be told they don't have a parts department any more :huh:
The nearest is about 40 minutes away, they do have a phone, but trying to order a part that you don't know what it is without seeing the screen is rather difficult.
24 Aug 2013 16:02 #80928
by j999pre
Grey pick up Jimny
A friend removed his old pipes in sections by cutting and pulling them through. The new one was made and then clipped in. warm the old clips with a hair dryer to make them less brittle.
Grey pick up Jimny
Time to create page: 0.378 seconds
