new engine
- deedar
13 years 2 months ago #80755
by deedar
Replied by deedar on topic new engine
How do I no what gear box is in my jim it I
It is a s reg the one I got iff that helps
- Dave cc
13 years 2 months ago - 13 years 2 months ago #80756
by Dave cc
Replied by Dave cc on topic new engine
If its s reg will be a g series engine so you will need the adaptor plate starter motor is not a must as you can grind some of the casing away to clear the block.
You will need baleno injectors bluey green ones i beleive and fit the jimny sump and mod the oil pickup
Also will need to fabricate one of the engine mounts not sure about cam sensor on a vitara engine but there tends to be some mods you need to do there as well
Dont be lead into the beleif its plug and play to do it properly takes a fair bit of time and no how
Last edit: 13 years 2 months ago by Dave cc.
- markyp2000
13 years 2 months ago #80757
by markyp2000
Replied by markyp2000 on topic new engine
This one is better
www.bigjimny.com/store/index.php?_a=product&product_id=120
If your using a vit engine i didnt think the sump needed to be changed as it is shaped like the jimny one i may be wrong
- jimnydms
13 years 2 months ago #80765
by jimnydms
Replied by jimnydms on topic Re:new engine
What engine is in the baleno does it still come in the smaller tax bracket ? Would it be hardly worth it ?
vitara_mad wrote: 16v vitara engine to a g13bb gearbox yes with adaptor plate also baleno or grand vitara engine
if you have the m13a I believe you need the liana engine
- deedar
13 years 2 months ago #80768
by deedar
So what's going to be best vitara engine to buy and what year
- deedar
13 years 2 months ago #80769
by deedar
And will I also be better mounting the block to the box sour of the car
Time to create page: 0.090 seconds
